The frame has a few places where the welds do not go 360 degrees around tubesT.his means that the tubes are open to the atmosphere and corrosion can occure inside these tubes. Corrosion is stopped if tubes are sealed and air no longer can enter the tubes. I used JB Weld epoxy to seal all openings today.
