Brief Description: attaching landing gear to frame
Checked one last time all dimension between gear and frame making sure everything is perfect. Next I drilled the holes for the rear gear hoop to frame attachment and inserted bolts. Next I determined the location to be drilled to attach the front gear hoop to the frame using a 1/4" transfer puncg which I put in the tube in the trame. Using a large clamp on the center punch marked the center of the hole to be drilled. Next i drilled the 2 holes in the front gear shoes. Cut the 2 spacer bushings for the rear gear and installed them. Inserted all bolts and nuts and checked all dimension. Everything looked good and the gear installation to the frame is finished.
