GOTTFRIED'S WEB SITE
Date:  1-12-2020
Brief Description:  pitot tube fabrication
made the pitot tibe today. Cut the provided sheet metal into theround shape, drilled the needed hole in a 60 degree angle and soldered the copper tube onto the plate. Then I installed it, lined it up and drilled the mounting holes according the drawing. Then I installed 3 nut plates.
base plate finished
base plate finished
pitot tube soldered onto plate
nut plates installed
