I had installed a rubber boot on the cyclic beam to protect he slider from dirt. Problem was that his black ruber boot caused severe corrosion on the beam. Even after cleaning up the corroded areas the corrosion would continue and i decided to replace both cyclic beam and the slider.
corroded cylic beam after clean up
ecided to replace beam and slider with a new unit from Eagle
