Brief Description: First engine installation in fuselage
Finally I can install the engine into the rame for the first time. Used my hydraulic table and it went effortless. Eagle had shipped a wrong size rod end, so the operation was on hold until the corect rodend arrived. Finall alignment of he engine is not et possible, because I am still missing the transmssion drive pulley, bu I will be able to start wiring the engine and do other hings. The oil filter turns out o be in a bad spot to ever exchange it andI most likely will have to position it somewhere else on the engine where I can easily service.
