GOTTFRIED'S WEB SITE
Date:  1-16-2019
Number of Hours:  3.00
Brief Description:  Rotor shaft bearing alignment
Time to align the upper rotor shaft bearing using shim stock. Also made up an adapter to be able to check the alignment with a dial. Eagle provides a collar to measure alignment, but using a dial is certainly the better way to go. Could align the bearing housing within 1/1000", which is well in Eagles requirements.
adapter to check alignment
alignment is within 1/1000
alignment is within 1/1000"
