GOTTFRIED'S WEB SITE
Date:  3-20-2016
Number of Hours:  3.00
Brief Description:  chin windscreen fitting to cabin frame
Started shaping the chin window. I had to take off about a 1/8' on each side to make it fit. Used my belt sander to remove the material, then used a file to put a chamfer on all around and sanded it smooth with a sanding block.
Chin window fits well into the frame, but I will finish installing the windshield before I will install the chin window.
shaping the chin window with belt sander
Fitting chinwindow to cabin frame
