After some more sanding on the instrument pod it is time to drill some holes. Aligned the pod with the lazer and drilled the most rearward 2 holes using my angle die grider with a 3/16 center drill. It cuts the fiberglass without chipping due to its high speed. After some more adjusting I drilled the most forward 2 holes. Alignment was stillgood, so I drilled the remaining 4 holes and installed the 3/16 boltd on temporay basis.
