Brief Description: Engine Pre-Oiling pt. 5: Second Attempt
Retightened oil pressure sensor fitting and cranked engine; oil pressure built up to 38 psi and stabilized Repeated test with same result. Engine is now pre-oiled; the process was captured on video. Shut down avionics; unplugged engine pre-heater, reinstalled bottom spark plugs; torqued all spark plugs to 35 ft/lbs and reconnected ignition leads. Checked propellor bolt torques; set to 65 ft/lbs.
