Heated engine using an oil radiator-style heater and the installed Reiff HotBands; case temperature settled at 60 degrees F. Sanded paint off of case area where the HotStrip would be attached; scuffed and cleaned case and back side of HotStrip . Used infrared heat lamp to increase case temp above 75 degrees. Mixed epoxy; spread on back side of HotStrip; applied to case and filleted edges.
