Reconnected, adjusted and secured prop governor cable. Remounted mixture cable bracket. Reconnected mixture bellcrank assembly to cable and bellcrank mounting bracket. Reattached mixture lever to bellcrank rod end; adjusted and secured mixture cable. Reconnected, adjusted and secured throttle cable. Torqued and sealed nuts; secured castle nuts with cotter pins.
