Brief Description: Upper Intersection Fairing Work pt. 5
Refit gear leg pocket covers. Worked on fitting left upper intersection fairing. Scraped inside surface of inside half against gear leg bracket bolts to determine initial location. Drilled pilot holes and reamed out; refit on gear leg to sight bolt heads and mark for additional trimming.
