Brief Description: Fabricate Fwd Baggage Door Supports pt. 2
Fabricated upper retaining spring and lower cross brace for baggage door supports. Lower cross brace is flared aluminum tubing that captures lower pin screws; flexed to insert or remove. May eventually be replaced by compression spring.
