Wiped down fuselage; mixed and sprayed first clearcoat. Mix ratios were slightly off; corrected on second coat. Called Sal Gomez at Sherwin-Williams; he said allowing longer drying time is all that's required. Inspection showed some clearcoat runs that will need future sanding and buffing, but coverage is good.
