Removed wheels, brakes, axles and shims from gear legs. Reinsalled axles and shims with temporary bolts. Cut two alignment guides using aluminum C-channel. Taped alignment guides to axles; strung monofilament line from one axle to another along the guides to check alignment. Checked forward and aft sides of axles; alignment good. Reassembled axles, shims and brakes on gear legs; torqued and sealed. Reinstalled wheels, leaving inner brake pucks removed and in storage.
