Brief Description: Wheel/Brake/Fairing Bracket Work pt. 12
Removed brake lines, calipers, wheels, brackets, jackpoints and axles from gear legs. Paint jackpoints with anodizing paint. Grove axle shims arrived from Van's; discovered I had accidentally ordered a caster shim and a toe shim instead of two toe shims. Called Grove; ordered two more toe shims directly and returned caster shim to Van's. Bolted, torqued and sealed right axle, shim, jackpoint and brackets assembly. Double checked toe in/out.
