MARTIN'S WEB SITE
Date:  10-12-2017
Number of Hours:  1.00
Brief Description:  Fuel System Work pt 1; Tailwheel Spring
Ordered firewall-forward kit, ES Airflow pump & filter and deluxe throttle quadrant from Van's; also ordered tools and misc parts from Cleaveland Tools and Aircraft Spruce. Began work on fuel system. Widened access hole for tailwheel spring bolt and removed bolt from mount. Lubricated and installed tailwheel spring. Removed bolts from WD-101 FSTW mount base and cleaned up damaged threads. Reinstalled bolts in tailwheel spring mount and FSTW mount base; torqued and sealed nuts.
