Fabricated alignment jigs using two 4' aluminum channels. Bolted channels to lower pair of axle bolt holes, leveled channels and aligned gear legs for zero toe-in/toe-out. Do initial check of distance between landing gear leg bottoms and tail spring mount to assure centering. Marked bottom skins for trimming to accomodate Grove outboard main gear attach brackets.
