MARTIN'S WEB SITE
Date:  8-11-2017
Number of Hours:  3.00
Brief Description:  Control Connections pt. 7
Calculated washers required for proper spacing of aft rod end bearing between elevator horns. Installed washers and checked elevator travel. "Down" angle within spec, but more relief is needed on bottom of left horizontal stabilizer rear spar flange. "Up" requires more relief on F-812B angle/control stop to gain additional travel and meet specs.
