MARTIN'S WEB SITE
Date:  6-8-2015
Number of Hours:  4.00
Brief Description:  Rivet Horizontal Stabilizer Rear Spar
Riveted HS-609PP bars to HS-603PP rear spar channels. Riveted HS-412PP and HS-413PP hinge brackets to rear spar assembly. Bolted HS-411PP center bearing assembly to rear spar assembly. Did not torque bolts; torque wrench needed calibrated to in/lbs.
