Brief Description: Weight and Balance Work pt. 4; Harness Work pt. 4
Double checked datum arm lengths and recorded all numbers. Refit carpet on C-frame table; moved table around to support tail for fuselage work. Removed aft baggage bulkhead; worked on fitting aft shoulder harness anchors. Reamed mounting strap holes; assembled anchors to straps and had difficulty trying to align castle nut slots with bolt cotter pin holes. More work required.
