Fit forward wing fairings and temporarily clamped upper intersection fairings in place; examined fit issues. Discovered leaking brake line fitting on left side. Elbow threads are ok; leak seems to be coming from brake line coupling. Photo was taken after the area was wiped off so the drip isn't visible, but the brake fluid softened the torque seal paint and it was removed during wiping.
