Mounted flaps and taped in fully up position; checked fit of bottom inner skin edges. Removed flaps; massaged skin for better fit. Laid out, drilled and dimpled rivet holes through corner where aft inner skins overlap. Squeezed rivets in holes to hold corners together and prevent airflow from catching forward-facing skin edge.
