Removed rudder. Reconected elevator pushrod to elevator horns with spacer washers in place; torqued and sealed. Bent and lubricated finished hinge pin for trim tab. Drilled hole in aft elevator spar for safety wire. Installed trim tab and hinge pin; secured with safety wire.
