MARTIN'S WEB SITE
Date:  4-9-2021
Number of Hours:  6.00
Brief Description:  Wheel Fairing Work pt. 6
Cut, trimmed and smoothed gear leg notch in right aft fairing multiple times to establish and refine fit. Marked rivet holes for U-808 bracket on inside of fairing with torque seal paint. Drilled two front holes, checked alignment, redrilled one hole and match-drilled remaining holes using angle drill. A fiberglass pad will need to be built up for the aft two holes to match the surfaces of the bracket.
