Drilled two #30 pilot holes; clecoed template to left wing tip and laid out trim lines. Final drilled holes to 5/32. Cut out holes for landing light with Dremel cutting wheel; shaped with barrel sander and smoothed with sandpaper and sanding blocks. Studied installation instructions.
