Rerouted left upper ignition wires above motor mount and secured. Researched hole with red plug in top of oil filter mount. Conferred with Allan Barret via text; he said that the oil temp sensor should be in that hole, not the hole in the accessory case (seen on the left in the middle photo). At first he said that was an NPT tapped hole, but as it turned out both holes are identical 5/8-18 holes. When the plug was removed from the hole, something green and gooey was revealed...
