Massaged latch pin hole in aft block and worked on positioning block so that latch pin would engage fully. Marked back of aft block with sharpie; removed and drilled #30 pilot holes on drill press. Match drilled through pilot holes in aft baggage bulkhead. Used drill bits, and later pins, to confirm positioning of all holes; checked alignment by latching with key. Enlarged all block mounting screw holes to #19; countersunk inward sides and inserted screws. To finish installation of aft block, placed socket wrench on each stop nut in turn to back side of aft baggage bulkhead and taped in place, then tightened screws in block from outside with screwdriver; torqued and sealed. Forward block was secured temporarily with jam nuts; block will need to be removed one last time to allow room for riveting of Skybolt flanges along firewall. Reconnected and reinstalled Garmin EFIS screen.
