Removed door and put on bench. Removing clecos revealed that the inner door skin rivet holes had been dimpled; CS4-4 flush blind rivets were required, and in stock. Began riveting inner skin to ribs, stopping occasionally to place baggage door on fuselage and checking fit to make sure door wasn't twisting during riveting. Finished pulling all rivets, including LP4-3 rivets along top edge of inner skin. Checked door fit with hinge pin in place; some interference caused by excess hinge tab lengths on both sides. Masked areas, trimmed tabs with hacksaw blade and smoothed edges with jewelers file.
