Removed top cowl and all Skybolt flanges along the firewall. Prepped, painted and relabeled left and right firewall shims. Removed front baggage door and marked line where bottom edge of baggage door skin would be bent to conform to fuselage skin. Clamped aluminum angle and straightedge to bottom of door skin to set bend; clamp assembly in vise and carefully bent bottom edge. Removed assembly from vise; taped baggage door back in place on fuselage and taped upper right edge of firewall (including baggage door support, forward top skin strip and firewall flanges) to fit properly against forward edge of baggage door skin.
