Determined the best rivet layout for Skybolt flanges based on 3.5" connector spacing. Four rivets spaced about 1.143" apart gives good spacing along the base of each flange. The mounting rivet holes in all remaining Skybolt flanges were drilled and deburred. The first rivet hole on the left is spaced 1/2" in from the left edge. The fourth (right) rivet hole will be matched drilled through the stepped flange using the first (left) rivet hole of the next Skybolt flange to the right. Unlike the Skybolt flanges along the firewall that had to be match-drilled to the existing rivet holes, the cowling Skybolt flanges were all pre-drilled to the ideal rivet spacing layout; the bottom cowling edge will be match drilled using the Skybolt flanges for the pattern.
