VAF member Chris pointed out that my rudder cables were incorrectly routed through the spar box. Fortunately the fix was straightforward. Removed the floor panels, triple-check the plans, enlarge the correct pilot holes to 5/8", disconnect the cables and reroute, install snap bushings and reconnect cables.
