Brief Description: Elevator/Stabilizer Work pt. 36
Another disturbing set of blemishes were these spiderweb type flaws; actually sharp ridges of raised up primer through the color coats. Uncertain of the cause, or exactly when they occurred. Suspect that they may have happened due to contamination in the wash primer or even below that. Some consultation with Sherwin-Williams is required.
