Brief Description: Elevator/Stabilizer Work pt. 26
Laid stand down with gray side up and sprayed on the clear coat. Waited for it to set up, then tilted the stand upright and wiped down the green side with wiping solvent. Laid the stand down with the green side up and sprayed on the clear coat. The technique worked well for both sides; the finished clear coat here is smoother than it was on the vertical stabilizer.
