Brief Description: Rudder/Stabilizer Painting pt. 11
Did some very light wet sanding over numbers with 600 grit sandpaper and touched up one area on the trailing edge of a white stripe that had a small spot of red overspray on it. Wiped down rudder with wiping solvent and applied two clearcoats; did the same to vertical stabilizer. Removed masking from vertical stabilizer and cleaned up. These are the first essentially finished airframe components.
