Brief Description: Rudder/Stabilizer Tip Work pt. 7
Began shaping top of rudder tip to conform to shape of vertical stabilizer tip. Removed rudder from vertical stabilizer and placed in rudder jig; clamped jig to C-frame table. Began work fitting rudder bottom. Worked on fitting tail strobe adapter ring. Planned wire routing for tail strobe. Match-drilled #40 holes in rudder bottom attach flanges and clecoed rudder bottom in place.
