Fabricated 2 AWG cables for battery/master relay and master relay/starter relay runs. Widened pilot holes in bulkheads to 1/2" and began routing. Couldn't get big drill into positions to widen holes to 5/8"; unable to use snap bushings. Tried using heat shrink tubing to protect cable from bulkhead edges. Not satisfied with result; pulled cable and rerouted with split conduit in place. Much better.
