Decided to rearrange the workstands to allow better access to the gear towers. Placed the smaller workstand under the aft cockpit bay, lifted the front of the fuselage with the engine hoist and removed the larger workstand from under the forward cockpit bay. An improvement, but still difficult. Managed to get one nut on the left forward bolt with the regular socket and extensions without having to use the borescope as a guide. Made up an adaptation on a smaller universal joint extension to allow clearance to get the nut onto the right forward bolt. Both aft bolts have clearance issues with bulkhead bolts seen in photo. Those bolts are blocked in place by fuselage skin screws, nuts and washers. Removed the screws, nuts and bolts to allow access to loosen or remove bulkhead bolts, nuts and washers in order to get nuts and washers onto aft outboard landing gear bracket bolts.
