Removed all clecos and centered fuselage on stand. Finished drilling upper hole for left tank attach bracket. Bent tab of bracket to fit flat against T-405 angle on fuel tank and bolted bracket in place. Clecoed right tank attach bracket to fuselage to check fit. Removed bracket and upsized bottom hole to #21 and #19 before final drilling to #12. Bolted bracket to bottom hole and centered bracket on top hole with cleco. Removed cleco and upsized top hole in same sequence. Bent bracket to fit angle and bolted back in place.
