In order to avoid drilling a hole in my exterior shop wall, I chose to feed the left aileron pushrod into the right wing and pass it through the fuselage. Turned out t be very difficult; had to dismantle the control column to do it, but it worked. Reassembled control column. Checked wing plans, collected hardware and attached pushrods to control column and bellcranks.
