Drilled two bulkhead holes and installed snap bushings prior to routing pitch servo harness. Removed female pins from Garmin pitch servo connector and routed pitch servo harness forward-to-aft. Secured harness, reinstalled connector, applied wiring conduit as needed and checked fit.
