Test fit forward baggage side and increased relief notch for EIS harness clearance. Mounted transponder rack in brackets. Put castle nuts and cotter pins in place on rudder cable attach bolts. Installed forward baggage side into fuselage with harnesses routed. Connected all EIS harnesses to EIS module and bolted to forward baggage side.
