Brief Description: Transponder and EIS Brackets pt. 3
Laid out, drilled, deburred and dimpled rivet holes in brackets and F-871-1 forward baggage side. Clecoed rack and brackets in place and determined location for EIS converter. Drilled holes and mocked in place. Planned wiring runs and rudder pedal hardware for interference. May have to use at least one flat head screw to mount the EIS converter to avoid fowling rudder pedal hardware.
