Created blueprint for ELT bracket in photoshop. Bent part to shape by hand, drilled and dimpled rivet holes and squeezed rivets. Use fluting pliers to draw part into proper dimension. Relieved stress areas with Dremel grinder. Bolted ELT tray to bracket, installed ELT and test-fit on fuselage.
