Refit rudder pedals and reconnected cables. Travel is good but the nuts/bolts that attach the F-852C forward rudder cables to the F-852A aft rudder cables contact the aft reinforcement rib of each WD-813-1 landing gear bolt weldment. Worst-case scenario could result in jammed rudder; several possible fixes; doing research. Also received missing FWF parts from Vans in good condition.
