MARTIN'S WEB SITE
Date:  9-1-2017
Number of Hours:  3.00
Brief Description:  Control Connections pt. 19
Relieved brake cylinder arm tabs slightly to allow more rudder pedal travel. Installed assembly in fuselage and checked; repeated until rudder travel is nominal. Removed and disassembled brake master cylinders, brake pedals and attach angles. Applied grease to rudder pedal tubes and rudder axles. Reassemble axles, pedals and brake tube arm and torque bolts to spec, marking with torque paint. Prepped and primed attach angles.
