Bolted U-806-1/2 inboard wear plates to Grove inboard main gear attach brackets and match-drilled 7/16" holes through both inboard wear plates. Bolted both Grove airfoil gear legs to the fuselage through the inboard brackets and wear plates, using a cherry picker for support.
