Brief Description: Mount Horizontal Stabilizer pt. 5
Clamped horizontal stabilizer to fuselage, double check all levels, layouts and dimensions, then match-drill four holes through all angles, spacers, shim and aft deck skin using angle drill adapter. Layout looked good, so finish-drilled all four holes to #12 size and installed temporary bolts, nuts and washers in each one. Check levels and dimensions again before final-drilling holes in rear spar and stab attach bars. Installed temporary bolts, nuts and washers.
