Brief Description: Assemble Aileron Pushrods pt. 4
Primed inside of all pushrod tubes. Press-fit AN490-HT8P threaded rod ends into pushrods and match-drilled rivet holes. Squeezed rivets to secure threaded rod ends. Installed jam nuts and rod end bearings on pushrods. Measured and drilled holes in angle iron for aileron jig.
