Brief Description: Rivet Right Horizontal Stabilizer Skin pt. 1
Riveted HS-707 replacement nose rib to top of HS-809PP right skin. Clecoed other ribs onto skin and set blind rivets along bottom of nose rib. Set blind rivets through HS-708 right middle rib, HS-702 right front spar and nose rib. Clecoed right skin to right front spar and riveted skin to spar and middle rib. Riveted right HS-706 , HS-00005 and HS00006 ribs to right skin. Installed and removed rear spar numerous times to facilitate moving of assembly during riveting. Clecoed rear spar assembly back in place and placed horizontal stabilizer on storage pending inspection and final riveting of rear spar assembly to both skins and all ribs. Martin Filiatrault - 8 hrs. Mike Oswald - 1 hr.
